Enables the MAC address lock down timeout feature for the specified port or group of ports or for all ports on the switch.
| all | Specifies all ports. |
| port_list | Specifies one or more ports or slots and ports. |
By default, the MAC address lock down timeout feature is disabled.
You cannot enable the MAC lock down timer on a port that also has the lock learning feature enabled.
The following command enables the MAC address lock down timeout feature for ports 2:3, 2:4, and 2:6:
enable mac-lockdown-timeout ports 2:3, 2:4, 2:6
This command was first available in ExtremeXOS 11.6.
